setup.exe is not opening
SB_9326571
3-Newcomer
setup.exe is not responding. Also not received any license file even after raising request
Hello @SB_9326571
Kindly refer the link
I hope this should help to resolve the issue
Vipul
Hello @SB_9326571 ,
DId you run setup.exe as administrator? Also, is there any error message you are getting or setup.exe is vanishing after executed?
SB_9326571
3-Newcomer
(To:VipulT)
Setup.exe is vanishing after running as a administrator
Hello @SB_9326571
Vipul
