How can I read a value from an ini file into a variable?
  • October 18, 2019
  • 2 replies
  • 5126 views
I have configuration files in INI format. I would like to read these in Mahcad. Can someone give me a tip as I can read the values ​​individually one by one in MathCad variables?
Something like a := READ(File,Section,valuename)
Best answer by Werner_E
Here is a first approach. Not much error handling included and will work for "well behaved" ini-files and numerical values only.
MC15 worksheet attached
diedrich1-VisitorAuthor
Even a solution for Prime is very welcome
Thank you very much
Here's the first incarnation in Prime 4:
Which also works in Prime express.
Corrected an error where it would miss the last character of a parameter value.
Since the ReadIni(file, section, parameter) approach doesn't care about comment statements, it's sort of immune to them. This function will even handle this .INI file  https://downloads.avaya.com/elmodocs2/ip_phones/r2_7/output/16_601433_2/IPTel_Server044.html
You'll have to be more specific about the structure of an "INI-file".
Example of INI-File:
Filename: 'Geometry.ini'
Content (ASCII-File):
[Cylinder1]
Hight=100.12
Diameter=25.123456
[PointA]
X=123.12345
Y=123458.3
Z=7.0
I would like to read the Value of MathCad Variable CylHight out of the INI-File.
I'm looking for something like:
CylHight:=READINI('Geometry.ini','Cylinder1','Hight')
Best regards
Werner_E25-Diamond IAnswer
