butterfly valve tutorial
  • April 8, 2013
  • 3569 views
hello,
where can I find the butterfly valve tutorial for Pro/E?
A couple of years ago, I did see it somewhere, but I can't find it now...
thanks and greetings
bern
It is one of the assembly "enhancement" tutorials. If you still have access to the eLearning Windback library, you can get to it.
Look for the "Creo Elements/Pro 5.0 (formerly Pro/ENGINEER Wildfire 5.0) Update from Pro/ENGINEER Wildfire 4.0" session. It has many tutorials using the valve assembly.
thanks, but I don(t have access to it...
Is it possible to get it from you?
That would be great.
thanks again,
bern
In the past (2008 or 2009) this tutorial for modelling the valve was free online.
I don't remember on which website it was.
I've lost my original files from then.
I would like to get this model_worflow for this val model...(pfd or so)
thanks,
bern
