How submit a solution for older case?
  • April 16, 2020
  • 3493 views
how can I submit a solution for a open case which is since 5 years not solved? (Case from other user)
Try to send a mail to cs_ptc@ptc.com with the subject "Case" number. So PTC can close this case and have a solution for other users! Get two times a error back.
Case tracker refuse the access. (Silver support level?)
Kai H.
Best answer by Pierre_M
Kai,
Sorry for the typo. it is indeed cs_ptc@ptc.com
You need to enter an existing case number (an incident with support), not an article number. If you do not have a case number, then you need to leave a comment using the widget on the right on the article (click useful yes/no and then leave your comment on the 2nd step)
If it does not work, just post your suggestion in this thread and I will convey it to one of our engineers!
Thanks again for your efforts
Thanks for your post and your willingness to share your tips with the rest of the user community, this is appreciated!
A couple of options for you (pick the one which is the most convenient for you)
  • Sending an email to cs_ptc@ptc.com with C######### in the subject line (where ######## is the case number) should work. The C before the case number is mandatory
  • Leaving a comment on the article itself and a support engineer will update the article accordingly
  • Posting your workaround in the community with a link to the article, and then the new thread in the community will automatically appear in the "related section" at the bottom of the article.
KaiHawaii1-VisitorAuthor
Sorry,
I used this mail adress cs_ptc@ptc.com.   You recommend cs-ptc@ptc.com (not valid)
Can´t leave a comment in the article. No rights?
What is the right case number for the mail subject? CS200189 or C200189?  (Both numbers testet)
Won´t call the phone support, my "talking english" is too bad. 😄
Kai H.
Pierre_M5-Regular MemberAnswer
Kai,
