Logging issues with the eSupport portal
I thought I would log an issue I'm having with the eSupport portal during case creation. eSupport is listed in the list of products so I assumed it would be straightforward to create a case for troubleshooting. Nope. It works fine to select eSupport as the product on the first screen but on the next screen where the case is actually created it's no longer a valid selection.
1st Page:
2nd Page:
It's too bad the 1st page doesn't limit the products displayed to the ones you're actually allowed to create cases for. It's also disappointing that a case can't be created to improve the behavior of the case logger itself. (ANY SCN should work to create eSupport Portal cases.)
