Sorry. Article 234144 was not found
  • September 3, 2018
  • 3711 views
Using the Technical Support Search with the term 'Application (UNNAMED): running public notification type 118, mode spawn' it returns 1 result:
https://www.ptc.com/en/support/article?n=CS234144&language=en&posno=1&q=Application%20(UNNAMED)%3A%20running%20public%20notification%20type%20118%2C%20mode%20spawn&source=search
When I click on this result it says..
Sorry. Article 234144 was not found. Here are some options:
Does anyone know why CS234144 is missing?  Is it a database issue or is the link incorrect?
    Best answer by Heidi
    @colenum thank you for bringing this issue to our attention. Our search team are looking into the issue. In the meantime you can find the information in this article https://www.ptc.com/en/support/article?n=CS246813
    Heidi5-Regular MemberAnswer
