Community Manager
May 29, 2025
Chapter 1: Level Setting Product Sustainability
  • May 29, 2025
  • 2 replies
  • 4032 views
Please copy the question below that most resonates with you with your answer in your reply. (It counts towards your Sustainability Badge!)
-How does the book define sustainability in the context of product life cycles?
-How do compliance and profitability drive sustainability efforts?
Personal Impact: How has your understanding of sustainability evolved over time, and what specific experiences have influenced your perspective?
Register for Sustainability Chat with PTC VP Dave Duncan July 10!
kdirth
Sustainability is much more than what is done within the walls of a manufacturer.  You must consider everything from the source of the raw materials to what happens to the product after its useful life is done.
Personally, I have at times, paid attention to what happens to something that is no longer useful, and I need to dispose of it.  Many things are full of reusable materials but are very difficult to separate into separate parts that can be recycled.  Some things can be separated, with some effort, but can the resulting small pieces get recycled?  Small items on the recycling belt often fall though or are not picked out for recycling.  Also, many materials are recyclable but there is not enough of a market to make it valuable enough to deal with.  That which does not get recycled ends up buried in the landfill.  And there are many things that just cannot be recycled or separated.
I have deconstructed many toys, machines, pieces of furniture, etc. (with help from the children) to recycle as much as possible.  How much actually made it into the raw material stream is anyone's guess.
Dale_Rosema
Our refrigerator in the office needed a $5 (I was going to say one dollar) dip switch replaced that failed. The problem was that the part was heat staked to a $250 module that had to be replaced. Less bolts and screws makes quicker production times, but is lousy for repair options. Throw out the whole old module. (After I looked at it and how it was designed.)
Sounds like poor "design for disassembly" on an expensive an oversized field replaceable unit.  If the $250 unit was returnable with reimbursement and then remanufactured, that's slightly better.  But it seems the dip switch should have been ID'ed earlier in design as a likely fail part and either be its own FRU or at least within one smaller than the $250 unit.  A commercial incentive could be mixed up here too - if the dip switch rarely fails within the warranty period.  As appliances gain longer service contracts or even leasing, the design incentives should improve.  Right to Repair and Extended Producer Responsibility regional rules will help the design incentive too.
I'll start by following the instructions, "Please copy the question below that most resonates with you with your answer in your reply."
I started reading the book, and before I even got to the first chapter, the introduction made this questionable assertion:
"You don't need to overhaul how you work today."
I have been working on a sustainable product design team for the past couple of years, and the first thing that we noticed was that we didn't even have a way to measure the Product Carbon Footprint (PCF) of a new design concept. As we set out to fix that, we realized that the problem was much worse. The available published EFs are spotty and primitive. Our procurement people were only starting to gather CO2 Emissions Factors for our raw materials, and many of our suppliers didn't have a clue. In short, our entire new product design infrastructure, in pursuit of profit, had evolved to systematically ignore externalities, including PCF. To evaluate new concept PCFs we had to collect massive amounts of proprietary material data and make it easily available to score new product concepts. PTC is finally catching up with this by linking part volume with material identification that includes EFs, but it still ignores scrap, which can more than double a PCF, and other inputs that I can't even talk about here. It's still a struggle to encompass an entire product with a LifeCycle Analysis (LCA) even at the production stage. While a team approach throughout the product lifecycle has always been essential to profitability, the need to find and choose more sustainable materials and methods continues to ripple through the entire organization, and up our supply chains. Even today, EFs are treated more like a cost, subject to change, than as a property, intrinsic to each material. How do we even specify a material for a part based on it?
Sustainability has become an essential requirement for profitability. So, while I agree that we do have to keep on using the tools that we have to make good products, the new tools that we are adopting are necessarily overhauling the way we work. I like to say, "If we always do what we always did, we'll always get what we always got."
TEChi, thank you for the comments - your details on the new work you're doing with sustainable design are helpful.
Regarding the book's statement:  "You don't need to overhaul how you work today."   The intent here was to note that existing integrated model-based and BOM-based approaches can effectively incorporate sustainability with attributes as material/part/manufacturing_process/configuration levels.  Likewise, requirements tracing can drive footprint reductions and simulation process can incorporate LCA's early and often as "environmental simulations".
And I agree with material management - at last, it's here!  So much footprint is in materials - it needs to be a first-class life cycle managed concept in PLM.
Also agree that upstream supplier data is tough to get today, and it's frustrating since that's where most of the footprint lies.  It'll improve over time with groups like the IDTA and their Asset Administration Shell standard.  In the meantime, innovative LCA providers like Makersite can receive BOM's with varying supplier data precisions and reasonably estimate the remaining gaps based on graphs of known and estimated supply chains.  Supplier data will be a jungle for a while - hopefully less so within 5 years.
Thanks again,
Dave
Die Möglichkeit ins Deutsche zu übersetzen wäre gut, Mail und Webside.
Gruß Mario
