Borrow Licence Days
  • July 1, 2019
  • 5512 views
Hello.
Using Creo 4, it's possible to change the number of Days to manage borrow license duration.
By default the maximum borrowing duration is 5 days. Through an environment variable (LM_BORROW_DURATION=0-14), it is possible to get to a maximum of 14 days.
I modified my parametric.psf file unsuccessfully. Any idea ?
Pierluigi
Best answer by LukaszMazur
I'm not sure if borrowing license tool reads .psf files. I'd edit parametric_borrow.bat in \bin directory and add the command there, e.g. here:
@echo off
set LM_BORROW_DURATION=14
set MC=unset
or simply add it as a Windows environment variable.
@echo off
set MC=unset
Thanks a lot.
It works.
I modified the borrow bat file and the maximum number of days is now 179 !
Pier
Yes thanks !
Now we have subscriptipon licences and the max number is 179 ! I confirm .
Pier
