CREO 3.0 -- how to get rid of version control?
Hello all,
Is there an option in config.pro to disable version control in CREO? Or a setting in Options?
Whenever I try to open a part that has the same name with another part in a different location, CREO 3.0 prevents me from doing that. The only way to get around it is to shut down CREO and start again, which is extremely annoying and time consuming. The error I get is in the picture below.
Thank you, Colin.
