Can no longer open DIAGRAM (.dgm) files in Creo
  • June 30, 2023
  • 1362 views
I am using Creo Parametric Release 6.0 and Datecode6.0.4.0
We know support for DIAGRAMS (.dgm files) is all but gone but we we do have a pertpetual license (54) and have been continuing to use them, with parameter 'enable_obsolete_modes=True'. But now we can't open the .dgm files any more and we are not sure what changed. Looking at the settings with Creo we see that enable_obsolete_modes has a 'stop' icon next to it (see attached). Doe this mean it is no longer working?
Best answer by KenFarley
I am using Creo 9 and "enable_obsolete_modes" is a hidden config option in this version. Could it be that it needs to be set to "yes" and not "true"? Hidden options can still be set - I use a few myself - but they won't be offered to you when you try to edit your config.pro from within Creo.
This is  a setting you are trying to make in your config.pro via the line:
enable_obsolete_modes yes
Correct?
KenFarley21-Topaz IIAnswer
Correct?
Yes, that worked! Thanks!
