Can't change Lanauage from English to Chenese traditional(Creo Parametric 4.0 M020)
hoshea
Hi Partners,
I want to run Creo Parametric in Chenese simplified.  (Creo Parametric 4.0 M020),
  1. I have the license available and added it when I installed it.
  2. I have added "ENV=PRO_LANG=chs" to the end of the .psf file and set the LANG and PRO_LANG environment variables.
  3. Modified the following options
dialog_translation yes
help_translation yes
msg_translation yes
menu_translation both
enable_popup_help yes
button_name_in_help yes
 It can't be helped.☹️
It works in the simulate module , even though the prompt window still pops up.😫
Any idea? Thanks.
VladimirN
24-Ruby II
(To:hoshea)
Articles:
hoshea
(To:VladimirN)
Thanks for your reply, but I've already tried the methods you suggested and I've explained it in my question. I might need to consult with my company's IT department for further assistance.
