Can't change Lanauage from English to Chenese traditional(Creo Parametric 4.0 M020)
Hi Partners,
I want to run Creo Parametric in Chenese simplified. (Creo Parametric 4.0 M020),
- I have the license available and added it when I installed it.
- I have added "ENV=PRO_LANG=chs" to the end of the .psf file and set the LANG and PRO_LANG environment variables.
- Modified the following options
dialog_translation yes
help_translation yes
msg_translation yes
menu_translation both
enable_popup_help yes
button_name_in_help yes
It can't be helped.âšī¸
It works in the simulate module , even though the prompt window still pops up.đĢ
Any idea? Thanks.
