Can't install Creo anymore
  • November 20, 2025
  • 2 replies
  • 1131 views
I'm currently working on Creo3.
I have a licence file for Creo7 (permanent) that I need for a new client.
I d'ont have subscription anymore.
When I'm trying to add this licence file (txt) while installing Creo7, installer seems to freeze.
File is for my computer.
Should I remove my previous licence ?
But I'm afraid to can not be able to work...
Best answer by Dom_CHENTRE
Hi alls,
I gave up.
The only solution I've found is to reconfigure FlexNet.
I suppress Creo3 licence and add Creo7 when I need it.
I suppress Creo7 licence and add Creo3 when I need it.
Thanks you everybody.
Q1: Is Creo7 license locked or floating ?
Q2: What network card is mentioned in Creo7 license ?
It's seems to be floating licence.
But I'm triyng to install licence server and Creo client ont the same computer.
1/ this network MAC address is default Ethernet card.
2/ Ethernet Card
3/ Flexnet seems to be installed.
It works with Creo 3.
For Creo7, I suppose that Setup Creo7 would update if necessary.
Dom_CHENTRE14-AlexandriteAuthorAnswer
Hi alls,
I gave up.
