Can't install Creo anymore
  • November 20, 2025
  • 2 replies
  • 1131 views
I'm currently working on Creo3.
I have a licence file for Creo7 (permanent) that I need for a new client.
I d'ont have subscription anymore.
When I'm trying to add this licence file (txt) while installing Creo7, installer seems to freeze.
File is for my computer.
Should I remove my previous licence ?
But I'm afraid to can not be able to work...
Best answer by Dom_CHENTRE
Hi alls,
I gave up.
The only solution I've found is to reconfigure FlexNet.
I suppress Creo3 licence and add Creo7 when I need it.
I suppress Creo7 licence and add Creo3 when I need it.
Thanks you everybody.
Q1: Is Creo7 license locked or floating ?
Q2: What network card is mentioned in Creo7 license ?
It's seems to be floating licence.
But I'm triyng to install licence server and Creo client ont the same computer.
Reply no.1 27-nov-2025
License file intended for Creo 7.0 work mentioned in your reply from ‎2025-11-21 02:20 PM contains following lines.
SERVER __HOSTNAME__ PTC_HOSTID=80-FA-5B-4F-A4-FF 7788
DAEMON ptc_d __PTCD_PATH__
The file also contains following line.
INCREMENT PROE_EssentialsI ptc_d 39.0 permanent 1 \
License file intended for Creo 3.0 work must contain also following lines.
Q: What INCREMENT line is contained in Creo 3.0 license file? Please publish this line.
Dom_CHENTRE14-AlexandriteAuthorAnswer
Hi alls,
I gave up.
