Can't install Creo anymore
  • November 20, 2025
  • 2 replies
  • 1131 views
I'm currently working on Creo3.
I have a licence file for Creo7 (permanent) that I need for a new client.
I d'ont have subscription anymore.
When I'm trying to add this licence file (txt) while installing Creo7, installer seems to freeze.
File is for my computer.
Should I remove my previous licence ?
But I'm afraid to can not be able to work...
Best answer by Dom_CHENTRE
Hi alls,
I gave up.
The only solution I've found is to reconfigure FlexNet.
I suppress Creo3 licence and add Creo7 when I need it.
I suppress Creo7 licence and add Creo3 when I need it.
Thanks you everybody.
Q1: Is Creo7 license locked or floating ?
Q2: What network card is mentioned in Creo7 license ?
It's seems to be floating licence.
But I'm triyng to install licence server and Creo client ont the same computer.
Reply no.2 27-nov-2025
If you want to run Creo 3.0 and also Creo 7.0 on your computer then you do not have to use Creo 3.0 license. You only need a Creo 8.0 license.
To implement this variant, the following steps need to be performed:
1.] uninstall installed FLEXnet license manager
2.] download installer of latest FLEXnet license manager
https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/compatibility/PTC_LMS_Download.pdf?sc_lang=en
3.] unzip downloaded file and run setup.exe to install FLEXnet license manager
... use Creo 8.0 license file
4.] run ptcstatus.bat from FLEXnet installation to very that PROE_EssentialsI license is available.
5.] Creo 3.0 ... open psf file in Notepad and and make sure it contains following line
ENV=CREOPMA_FEATURE_NAME=PROE_EssentialsI ()
6.] start Creo 3.0
7.] Creo 7.0 ... open psf file in Notepad and and make sure it contains following line
8.] start Creo 7.0
Dom_CHENTRE14-AlexandriteAuthorAnswer
Hi alls,
I gave up.
