Can't install Creo anymore
  • November 20, 2025
  • 2 replies
  • 1131 views
I'm currently working on Creo3.
I have a licence file for Creo7 (permanent) that I need for a new client.
I d'ont have subscription anymore.
When I'm trying to add this licence file (txt) while installing Creo7, installer seems to freeze.
File is for my computer.
Should I remove my previous licence ?
But I'm afraid to can not be able to work...
Best answer by Dom_CHENTRE
Hi alls,
I gave up.
The only solution I've found is to reconfigure FlexNet.
I suppress Creo3 licence and add Creo7 when I need it.
I suppress Creo7 licence and add Creo3 when I need it.
Thanks you everybody.
Q1: Is Creo7 license locked or floating ?
Q2: What network card is mentioned in Creo7 license ?
So, I don't have subscription anymore.
I'm still have my Creo 3 (advanced) permanent  and floating.
With Isdx, Mdo, Mdx...
Now, I have to add an other licence Creo 7 Essential.
I wanted to install both, and having choice of licence with little menu as I've done in the pass.
Now, I'm using setup. exe for install licence.
I need to remove the other one and add licence file.
It works for Creo3 and Creo7.
But the other one doesn't works anymore.
I wanted to have choice
Here are 2 licence files...
Reply no.1 28-nov-2025
I uploaded merged_licenses.txt file. It contains two Creo licenses:
#PROE_EssentialsI 1 Creo Essentials Creo 8.0 Flt Lic perm
#PROE_EngineerIII 1 Creo Engineer III Creo 3.0 Flt Lic perm 3A320867
Now you have to execute following steps:
1.] uninstall installed FLEXnet license manager
If you do not know how to uninstall FLEXnet then send me list of installed programs.
Please read https://learn.microsoft.com/en-us/answers/questions/3995739/how-do-i-print-a-list-of-all-installed-programs-ap page
a.] open Command Prompt as Administrator
b.] run winget list >c:\apps.txt command
c.] send me c:\apps.txt file
2.] download installer of latest FLEXnet license manager
https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/compatibility/PTC_LMS_Download.pdf?sc_lang=en
3.] unzip downloaded file and run setup.exe to install FLEXnet license manager using merged_licenses.txt file.
4.] run ptcstatus.bat from FLEXnet installation to very that both licenses are available.
5.] Creo 3.0 ... open psf file in Notepad and and make sure it contains following line
ENV=CREOPMA_FEATURE_NAME=PROE_EngineerIII ()
6.] start Creo 3.0
7.] Creo 7.0 ... open psf file in Notepad and and make sure it contains following line
ENV=CREOPMA_FEATURE_NAME=PROE_EssentialsI ()
8.] start Creo 7.0
Dom_CHENTRE14-AlexandriteAuthorAnswer
Hi alls,
I gave up.
