I tried to open in creo 3 M140 but few files can open.
i have attached error message.
I also tried to open in creo 3 M170 the one that cannot open in old datecode but still, not all .prt file can open.
Is there any other way to open all .prt file from NX 11 to creo 3?
Thank you in advance.
NX 11 data can import in Creo 3.0 M150 and later. For earlier versions you can use neutral formats (iges...strp etc)
Here is the compatibility chart for Creo up tp 3.
https://www.ptc.com/en/support/article?n=CS275340
Here is the compatibility chart for Creo 4-6.
Thanks for all your replies.
It really help and very informative.
