Just copied the start folder, config pro, etc from a creo 2 installation to a creo 3 installation on another box, and custom mapkey icons and ribbon tabs are missing (even though the "creo_parametric_customization.ui" in the start folder was also copied.
Any ideas why? Where else does Creo store things, that need to be copied over when moving to another PC?
UPDATE:
Got the icons and tabs back by manually reloading the UI file and then saving, but still missing favorites and font settings.
