Creo 1.0 Ribbon Question
  • February 14, 2012
  • 3 replies
  • 1265 views
Have just got into using Creo 1.0 a little bit and found that theribbon tabdisappears when you click on the geometry screen to do something.....same with actual command tabs. You have to go back up & click the ribbon or command tab everytime you want to choose another command or do something within that command tab??
Is there a config that allows you to keep the icon ribbon open until you pick another ribbon tab or command?
Darin
This is because you have minimized the ribbon. If you double click the
ribbon tabs or click the arrow on the far right of the ribbon it will
become maximized again. This is standard Microsoft behavior
Paul Sagar
If you right click in the menu area of the ribbon you will see the 'minimize' function
you can check off and on.
Gary Miglionico
Brookhaven National Lab
How is everyone accepting this issue and your response? I released Creo to a select few users to play with and they want to hang my from the yard arms like it is my fault PTC changed the ribbon functionality. This process has made more steps for the users as I see it.
