Creo 2.0 does not open
  • March 1, 2018
  • 2 replies
  • 7327 views
I am a student and I have Créo 2.0 M130 with a valid student license.
Since some time, all Créo software do not open (even as administrator)
And there is nothing in the task manager
Some ideas?
Thank you
(Sorry for my English)
Best answer by lulu9501
I solved my problem that came from windows
I reinstalled windows and creo and it works!
Thank you everybody !
Ludovic
lulu950110-MarbleAuthor
Thank you for your answer dschenken
It is'nt a license problem !
Ludovic
22-Sapphire I
March 1, 2018
You mentioned nothing in task manager, still check for xtop under processes. If not, check xtop.exe in <Install _location>\Common Files\<Datecode>\x86e_win64\obj.
Also check the size of file, sometimes Anti-virus application quarantines the executable.
xtop.exe is not in the task manager, and when I try to execute it, there is a message saying that the application failed to start correctly (0xc000007b).
Tank you
Ludovic
Something does happen. The OS tries to load and run the application and some part of the OS or the application fails. The problem is there are too many places for the process to fail to list all that might apply to your computer. If this was a common failure it would have been fixed. I'm guessing that this failure has occurred before any part of Creo is actually running, otherwise you would have mentioned the presence of log files that are typically created.
You may have a better time with Stackoverflow, where diagnosing this type of problem is a more frequent activity.
Here's a link to Stackoverflow questions already asked about that error:
https://stackoverflow.com/search?q=0xc000007b ( the first result also suggests using dependencywalker utility, just like on the page I suggested before, and further that there is a mismatch in some dll type, which you will only find with dependency walker or some similar tool set such as the Windows Sysinternals utilities https://docs.microsoft.com/en-us/sysinternals/downloads/ )
