Creo 2.0 does not open
  • March 1, 2018
  • 2 replies
  • 7327 views
I am a student and I have Créo 2.0 M130 with a valid student license.
Since some time, all Créo software do not open (even as administrator)
And there is nothing in the task manager
Some ideas?
Thank you
(Sorry for my English)
Best answer by lulu9501
I solved my problem that came from windows
I reinstalled windows and creo and it works!
Thank you everybody !
Ludovic
lulu950110-MarbleAuthor
Thank you for your answer dschenken
It is'nt a license problem !
Ludovic
22-Sapphire I
March 1, 2018
You mentioned nothing in task manager, still check for xtop under processes. If not, check xtop.exe in <Install _location>\Common Files\<Datecode>\x86e_win64\obj.
Also check the size of file, sometimes Anti-virus application quarantines the executable.
xtop.exe is not in the task manager, and when I try to execute it, there is a message saying that the application failed to start correctly (0xc000007b).
Tank you
Ludovic
I opened parametric.exe with dependencywalker, there are many errors of DLL file not found (with names starting with "API-MS-WIN-CORE")
What are these files?
Thank you
