Creo 3.0 mapkey/ribbon issues
  • October 29, 2015
  • 3 replies
  • 3083 views
We recently upgraded to creo 3.0 m060 from creo 2.0.
One problem we are facing is that some mapkeys added to the ribbon stopped working.
The mapkeys work if we type the text on the keyboard, but adding them to the ribbon nothing happens. The buttons don´t do anything.
What the mapkeys do is open a config file and open a file.
This only happens in two computers. The others works fine.
Anyone experienced this?
Best answer by Jose_Costa
Rebuilding a new ribbon from the scratch in Creo 3 has solved the problem.
Jose,
This is such an open question because we have no knowledge of your set-up configurations so with what little was offered, I suggest to see if the two computers share the exact same .ui and .pro files as the other ones that do work. Make sure that any local/user created .ui and .pro files are nullified.
ron
Sorry, I forgot to mention that all the computers use the same .ui and .pro files.
Jose,
can you publish problematic mapkeys ?
MH
Sure,
See attached files.
Mold.pro is a configuration file loaded by the mapkeys.
All of them work for me on Creo 3.0 M010. Just make sure you rename the "lingua" mapkey to "lingua0" as suggested by Martin, then remove and reassign the icons on ribbon menu.
Jose_Costa12-AmethystAuthorAnswer
