Creo 3 M100 - Windows 10 unstable
  • August 11, 2016
  • 3 replies
  • 7046 views
Hi there,
I am struggling with Windows 10 (and therefore IE11) and Creo.
Using PDM Essentials through the embedded browser is like a minefield. Any user action (no matter, if activating a workspace or browsing common space) can cause Creo to stop.
Strangly enough, when Creo stopped responding to any input and I try to close it via right-click on Creo Symbol in taskbar -> "Close Window", Creo asks for confirmation instantly. But the dialog does not respond to any click.
I already tried "browser_limit_to_ie9_mode yes", but no success.
Does anyone have similar problems in this combination (Windows 10 & Creo 3 M100)?
    Best answer by Mat
    the bug seems to be resolved with version M140.
    Mat16-PearlAuthor
    I narrowed the problem to a script sequence of the browser's homepage.
    There are two lines, that do not work together:
    window.open("<weblink tool collection>.html", "", "width=1100, height=720");
    document.location.href = "http://<company windchill site>";
    I downgraded to Creo 3 M080 (last Version installed on my old Win7 system).
    Now, everything seems to run stable.
    So, seems like there is a bug in M100.
    Mat16-PearlAuthor
    I marked this thread as "unanswered" because the problem is still not fixed in M110.
    And keeping stuck in one Software version seems not quite being a solution.
    did you report the problem to PTC Support ?
    MH
    18-Opal
    October 11, 2016
    Have you tried setting the config option:
    windows_browser_type CHROMIUM_BROWSER
    We are on Creo 3.0 m100 and Windchill 10.1 m040 and that is what we had to do to get it to behave.
    Mat16-PearlAuthor
    Hi Marc,
    sure, I could try this, but my site uses weblink API, which is based on ActiveX (IE only).
    Meanwhile, I have got an answer from my reseller.
    PTC is already aware of the problem. A fix should be available with M120.
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS244548
    20-Turquoise
    October 12, 2016
    Matthias Rehs wrote:
    Hi Marc,
    Actually weblink works good with the Chromium based embedded web browser.
    Mat16-PearlAuthorAnswer
