I have updated to M140 from M110 but whenever I attempt to open any file (.asm or .prt), it instantly pops up a fatal error. I have uninstalled and reinstalled 4 times with no luck. When operating with M110, I experienced no issues. My other users were all able to upgrade to M140 and have had no issues opening the exact same files I have attempted to open. Anyone experienced anything similar?
You may try renaming the cache directory (.wf)
By default it is at C:\Users\USERNAME\AppData\Roaming\PTC\ProENGINEER\Wildfire
