Creo 8.0.6.0 crashes on model open
I have a Creo assembly (saved as from another assembly) that, when I go to open in Creo, crashes the session.
I provided PTC Tech Support with the assembly and they can't replicate the crash - i.e. it opens fine on their end. It doesn't open on any of the systems we have.
I can only open the model if I select "Open Subset" and then activate the Master Rep from within there. But if I forget and from Windchill select "Open In Creo", it crashes Creo. The same crash happens if I export the files to the C:\ drive and open from there so it isn't Windchill related.
Creo writes a handful of files in addition to the traceback.log to the start directory. And it's been writing a Creo file in there that doesn't open in Creo ("Cannot retrieve file" says the error when I tried).
That Creo file is explicitly called out in the std.out file:
Is there a way to find out what the file is in real life? Does anyone have any other troubleshooting exercises or codes to decipher the traceback.log or std.out files?
Does the process ID in the traceback.log match up to a process ID of a particular service that I can trace back to ?
I thought this was related to some circular references that existed but at this point all of them are resolved and the file still crashes.
Any help is much appreciated!
