Creo Parametric 7.0.2.0 crashes using config option "sketcher_diagonal_constr Yes"
Hi everyone,
Creo parametric - Release 7.0.2.0 crashes prematurely if config option "sketcher_diagonal_constr yes" is set and when you use the "Replace" function in the sketcher. To reproduce this issue do the following:
- Open Creo parametric - Release 7.0.2.0 without any configurations but only with opiton "sketcher_diagonal_constr yes". All other options are now default!
- Create a new part without standard part. Use option "Empty" to create that part.
- In new part create standard datum planes and create first geometry using protrusion on one of the standard datum planes
- Sketch a rectangle and leave Sketch, finish this feature
- Enter the sketch of this feature again using "Redefine" and draw an arc/spline/additional lines with the intention to use the "Replace" function from up popping Mini Menue in the sketcher. While sketching watch the snapping functionality trying/offering where to snap showing this with appearing/disappearing dotted lines.
- Select an existing, old line and click "Replace" from the up popping Mini Menue. Then select the new line/arc/spline to keep. A confirm window with options Yes/No appears. Selecting "Yes" Creo crashes.
- If it doesn't crash leave the sketcher and repeat the "Redefine" several times like described above. After some Replace actions it will crash reproduceable.
How ever, setting the config option "sketcher_diagonal_constr NO" the version 7.0.2.0 runs fine.
