3-Newcomer
January 31, 2024
Creo Simulation Live Internal Volume feature failures
  • January 31, 2024
  • 2 replies
  • 1388 views
I am using Creo Parametric Release 8.0 and Datecode8.0.4.0
Internal volume for fluid analysis cannot be created as no single solid surface exists as a boundary surface on one side of an internal volume (irregular nozzle orifice). Attempts to create a bounding surface have failed, including creating boundary blend surfaces and thickening them to create a selectable solid both surrounding the intended boundary and covering the intended boundary.
Here are the errors that I faced
[Internal Volume] Feature failed to regenerate.
The system could not create closed volume.
Recommended actions:
First, check the selection of bounding surfaces. Make sure all the surfaces that bound the volume are selected. Remove irrelevant surfaces from the selection. Then, check the selection of seed surfaces. Make sure seed surfaces are selected from the volume envelopes. Avoid selecting surfaces with multiple
outer edge loops. Make sure that each opening to close must be surrounded by a single surface, either a bounding surface or a fill holes surface.
Best answer by Amol_Lungare
Hi @WP_8071029
I believe the recommended actions should work: "check the selection of bounding surfaces. Make sure all the surfaces that bound the volume are selected. Remove irrelevant surfaces from the selection. Then, check the selection of seed surfaces. Make sure seed surfaces are selected from the volume envelopes. Avoid selecting surfaces with multiple
outer edge loops. Make sure that each opening to close must be surrounded by a single surface, either a bounding surface or a fill holes surface."
Amol Lungare
Hi @WP_8071029,
Did the recommended actions mentioned by you help? If not, would it be possible for you to share the file?
Amol Lungare
Hi @WP_8071029
Let us know if the file can be shared with us.
Amol Lungare
Hi @WP_8071029
Amol Lungare
