Creo window size
  • December 10, 2015
  • 2 replies
  • 3873 views
is there a way to adjust the padding on the right side of the creo window?  i dont mind my menus being docked.  i just want the window set wider.  i have 3 note files i leave on that side.  the icons are small, so, i would like the window to jonly allow those icons visible.
thanks in advance.
    Best answer by dgrobe
    no, i trying to leave a small space on the right.  i figured it out..
    the option is in the configuration editor
    reserved_menu_space i set it to 0.5.  didnt realize i needed to restart creo for it to take effect.
    22-Sapphire I
    December 10, 2015
    Daniel,
    Do you want to keep Creo Window in maximized state? If yes, you can use config option open_window_maximized
    dgrobe1-VisitorAuthorAnswer
