Distributed Batch
  • December 14, 2017
  • 3 replies
  • 2115 views
Creo 3.0 M120
ptcdbatch will not connect to Creo.  The log file indicates a failure at that point.  Anyone experience this and know a fix?
22-Sapphire I
December 14, 2017
When creating the task, did you specieid the DSM type to standalone?
Yep, I did.
what is your regional environment ? ptcdbatch has problems in non-English environment. In Czech environments I had to edit ptcdbatch batch file located in Parametric\bin sub-directory. I added following command line at the beginning of the file.
set PRO_LANG=english
22-Sapphire I
December 25, 2017
Did you get a chance to try using variable mentioned by Martin?
