Hi
can't batch print from registered Windchill (Intralink 9.1 M040/Pro/E WF5.0 M090) server (see attached error message). I have no problems printing from stand alone "Creo Elements/Pro Distributed Batch". Have you been able to print from the registered server? Would be nice to know how...
You can set your output dir in "Creo Elements/Pro Distributed Batch" with #Edit #Preferences #Directory for Output Files. In the same dialog you can set search options for *.ttd files with your own settings. There is a description for this in the "TOOLKIT User Guide" from the knowledge base. Have attached an example for s/w pdf printing. The original can be found in the <load point=">\proe\text\ttds folder.
thanks
Jan
