Drawing scale control while saving a drawing file as PVZ file
  • April 3, 2013
  • 0 replies
  • 892 views
Is it possible to control the drawing scale to 1:1 while saving the drawing file as *.pvz file? This can check the measurement in Creo View Express with the default drawing scale 1:1.
Customer except that there is a config.pro option controlling the drawing scale to 1:1, such as dxf:
dxf_out_scale_views yes
Or is there a method about setting the default drawing scale in Creo View Express? When I open Creo View Express, the default drawing scale is 1:1.
