Drawing templates: Historic up-issue
  • May 3, 2019
  • 2 replies
  • 5066 views
I've seen, maybe with other CAD packages, a way that the drawings keep a log of historic up-issue's. How does everyone manage that here? At the moment I'm creating new drawings, saving it with a different file name and only including the modification that required the up-issue for that one drawing. Ideally I'd like to keep a log of the modifications from initial drawing through to the current iteration.
I hope that makes sense?
What's an up-issue? I'm not familiar with that term.
Hi Dave,
It's an increment of an issue number on a drawing. Maybe slang that I've gotten used to using!
I don't know what an issue number is... that might be a process or terminology specific to an industry or companies I haven't worked for.
Is that like a revision number?
joe_morton
18-Opal
18-Opal
June 17, 2019
Are you using Windchill to manage your files? Windchill keeps the history of the drawing, so there's no need to change the filename. We keep a manual table on ours for the engineer to enter information on what changed in that particular revision
No I'm not using Windchill.
It was that table that I was trying to find an automated method of updating after each change. I'm guessing it's a manual process.
Share the information via ProjectLink.
And to clarify, what information do they need? While I can see that some revision information would be necessary, I don't see why they need would information like the signature block.
