FORMAT VS DRAWING SETTINGS
- March 10, 2017
- 4 replies
- 6310 views
I have a .dtl file saved for/with my formats (when I was creating them) they over-ride the Creo Default font sizes in some instances.
When someone starts a new drawing using my format, does their .dtl file on their C: drive over-ride my formats' settings or is the format the trump?
IE:
If my co worker's .dtl file designates the default font size as the Creo default (0.15825 or whatever it is) and my format's default is at 0.125, which size will the font be on the drawing they start with my format?
Z
Bonus points:
Is there a way (via config.pro or some other setting) to permanently UN-check the box "Use Default Template" (see attached image)
Thanks (2X)
Z
