Flexnet Publisher 11.14
  • February 7, 2017
  • 3 replies
  • 13367 views
I want to start playing with Creo 4.0. The readme says I need to upgrade our license server to Flexnet Publisher 11.14. I can't figure out where to get it from. I found a video that shows how to get to the download links for flexnet publisher but they are for 11.13. Where do I need to go to find 11.14?
Best answer by SamuelBrantner
Hi Michael Cormack‌,
I just figured it out
Follow these steps:
Greetings Sam
Flexnet Publisher 11.14 is included in Creo 4.0 installation medium, only. So you have uninstall FLEXnet and install it again using Creo 4.0 installation medium. I do not know how to extract Flexnet Publisher 11.14 from Creo 4.0 installation medium to get standalone installation package. Maybe you can ask PTC Support where to get standalone installation package.
MH
Follow these steps:
Greetings Sam
Marshdamp1-VisitorAuthor
Thanks Sam! I Will have our IT give it a try on the server.
This did not work for us
This is an old post, but if anyone stumbles upon it during a search you can also download the standalone FlexNet Publisher from the links in the following document:
PTC FLEXnet Publisher
- latest version under eSupport > Platform Support > Products
This KB article lists required FNP version by Creo release:
https://www.ptc.com/en/support/article?n=CS154266
All three links pointing to a documentation not to an installable FlexNet Publisher.
Jan,
The PDF document has links to download various FlexNet versions directly. It does require a login to PTC.com support.
