How do you manage your Pro/ENGINEER configuration files?
I know there are several methods for managing Pro/ENGINEER configuration files. I would like to build a list of the various, or at least most common solutions.
I will start by briefly describing my favorite. This works very well in a single-site Pro/ENGINEER configuration.
1. I centrally manage all "corporate" configuration files on a shared network drive called "ProSystem" and map it to the P drive for each Pro/ENGINEER user. I have also seen "pro_stds" as the folder name. These standards are read-only to the Pro/ENGINEER users and only a couple of responsible individuals have read-write permissions.
2. A shortcut on the desktop for each user points to the Pro/ENGINEER launch script at P:\bin\proestart.bat. The launch script is a batch file and can perform various actions like cleaning up the startup working directory, offering users a choice of what Pro/ENGINEER license to run, or allowing an upgrade testing team to run Pro/ENGINEER Wildfire 5.0 from the same desktop shortcut as Pro/ENGINEER Wildfire 3.0.
3. Among other things, the launch script copies the corporate standard configuration files (P:\configs\config.pro, config.sup, config.win) into the text directory of Pro/ENGINEER before launching Pro/ENGINEER. It also sets the Windchill local cache to a unique and accessible location.
The standards are secure, only modifiable by qualified people. Updates to the standards are easy to roll out, just make changes to the ProSystem content and the users' standards will be updated the next time the start Pro/ENGINEER. The infrastructure can be extended to support multiple sites relatively easy. I create identical ProSystem structures on each of the replica servers and use a distribution script to clone the master set of configuration files to each of the file servers.
It isn't a perfect solution. I've found it challenging to support individual remote or off-line users.
It goes without saying that this technique or any of the others that get posted here are not supported by PTC. However, it works very well for me.
What are your techniques? Don't get too detailed yet. The idea is to vote on the responses and then detail the more popular techniques.
Matt
