How to reduce an STL model to something more manageable?
Hello, I have an STL file that was created from a 3D CT scanner. I am now in the process of creating a parametric model from it but I am running into a bit of a problem. The STL is 500MB and contains 9,705,964 facets which is making my CREO run real slow and it typically crashes when saving. Does anyone know how I might reduce the resolution of the model or speed up the load times? Thanks!
