How to use Multiple Configuration in Assembly
Hi Guys,
I have an assembly eg. "X" and within the assembly there is one more assembly eg. "Y" and I need to assemble this assembly at variable angles.
Now the assembly "X" will be used in a new upper level assembly eg. "Z".
I am using multiple nos of assembly "X" into assembly "Z" but the placement angle of assembly "Y" subjected to variable in every case. I won't save a new assembly for every cases so I want to keep it same as assembly "X" but within the assembly "Z" It should have an option to change the angle of assembly "Y' without making any other new assembly.
Does anybody have an idea or any method expect "Family Table" feature.
Yogesh
