Hi!
First time poster here. I'm sorry if I'm in the wrong place.
Long story somewhat short:
I use creo parametrics 8.
After adding new fonts to my c/windows/fonts folder, I opened creo to find it looking like this (see attached photo)
I have tried changing UI font size to small, doing a different font.. None of it has made a difference. There are no changes to any other software on my computer.
Any helpful ideas for a fix?
Thank you!
try adding config.pro option according to the following example
default_ui_font italic bold, 24, times
https://www.google.com/search?q=creo+MENU_FONT&oq=creo+MENU_FONT
Hi Chris - Tried that one already unfortunately, but thank you for trying to help!
Thank you! That made the viewing experience loads better - It looks different from the UI my colleagues are looking at, but now it's usable. What's strange to me, is that they have the same settings in the config.pro file that I used to have before the fix.. But regardless, thank you loads.
