Installation problem
  • August 16, 2010
  • 2 replies
  • 2063 views
Hi all,
i am trying to install Wildfire 5 on my Dell laptop, but without success. I am attempting to install it without any license running to start with, something that i have just done with other 3 workstations in the office recently, just to get the software installed, i then re-ran the ptc-setup & added the license information when that became available. Even without a valid license pro-e would start, & i would get an error message about no valid licence being found, but with this new installation on my laptop, it will not even fire up. I get an error message about no valid psf file being found & that i must run the ptc setup file to be found in the bin directory. I have done this 3 or 4 times already but to no avail. When i run the setup file it creates the psf file, i can see it in my startup directory, so i don't see what the problem is. Anyone have any idea what the problem might be. My laptop is a Dell Inspiron running windows 7 home premium edition (64 bit), i think the graphics card is supported, its an ATI Radeon if my memory serves me correctly.
John
Hi John,
Please check if you have 64bit version installed.
BR
Marek
hi jhon
here some tips that may help u
switch off the firewall and antivirus
check the set is for 64 bit windows 7
check the license for valid
if its is installed in your laptop use single node locked license
try it
