7-Bedrock
July 17, 2016
Is it possible to access the extensions to CreoEssentials locked license by startup from other PC ?
  • July 17, 2016
  • 1166 views
We have both 1 seat of creo Essentials-Floating with ISDX locked license at System A) and Creo Essentials-node locked license at System B,Is it possible to use ISDX with Creo Essentials locked lic at Syst-B by Startup config?
Best answer by MartinHanak
answer to your question ... it depends on the contents of license file related to Essentials-Floating with ISDX locked license.
If this license file contains only one INCREMENT line then ISDX module is included in Creo license and you cannot use it on System B.
If this license file contains two INCREMENT lines (one for Creo license and one for ISDX module) then you can use it on System B (I hope).
MH
MH
