Issue facing when working in creo config-last_session_directory_path
vkumar-10-11-123
We are facing below issue when working in Creo. Every time save or regenerate,below window hurdle us. Please check and advise.
Vijayakumar J
look for following options inside your config.pro files and check their values
LAST_SESSION_DIRECTORY_PATH
LAST_SESSION_RETRIEVAL
To forbid saving session information, set
LAST_SESSION_RETRIEVAL  no
MH
Martin Hanák
MH
Martin Hanák
You likely have set the last_session_directory_path to a directory that you do not have write access permission. If you wish to use this option, you will need to specify a valid directory that has appropriate read/write access for the user.
