License Failure
  • February 19, 2015
  • 5 replies
  • 2655 views
Hi Everyone,
I have a been working with PRO-E with no issues for last 2 years until today, after a windows update and an update to my wireless link, I have lost access to my PRO-E, it keeps coming up with a message 'License request fail - invalid host'. Does anyone know how this can be sorted out such that it starts to work again. Hopeful for some answers to resolve it. Thanks Phil
Best answer by pewalker
Hi everyone,
Thanks for all the suggestions, it is appreciated. I have had the puzzle resolved by support, who were able to identify that the main network card for which the license is tied had become disabled. I don't actually use the main card as everything is on the wireless link, but because this had become disabled there was nothing to indicate that this was the case as only the Pro E was affected.
It was then a simple action by support who identified the issue via a remote link and resolved very quickly, so I am back up and running.
Thanks for all those who replied to my post.
Cheers
Phil
Is the license serevr host up and running?
Is the FlexLM license management software running?
Did the system upgrade change the order of the NIC cards?
Is the active NIC address on the license server the same as the one in the license file?
Mahesh_Sharma
22-Sapphire I
February 19, 2015
Phillip,
Seems due to Windows update, network card priorities on your machine has changed. If you are in active maintenance, please open a support case.
Phillip,
Try to use the option "Reconfigure Software Licenses" on PTC's site: http://www.ptc.com/appserver/lm/rsl/reconfig.jsp
Philip,
inside your license.dat file, you can find MAC address and name of computer, that was used during FLEXnet installation. Both information must be valid for your computer.
To check MAC addresses of network cards, you can open Command prompt window, launch ipconfig /all command and look for Physical Address info.
Martin Hanak
pewalker1-VisitorAuthorAnswer
Hi everyone,
Cheers
Phil
