License found during installation, but when starting CREO 7.0.1.0. cannot connect to server
We have run into a problem setting up our floating licenses. The server is up and running and the licenses are found with no problems during the installation. However, when starting CREO Parametric, the program is unable to connect to the license server... Initially, the port was blocked, but before that issue was lifted, the server wasn't even found during the installation.
How should we go about fixing this?
