Lights file in start part
  • October 20, 2014
  • 2833 views
Good morning.
When I look at the lights (View, Model Setup, Lights) in my models, they have the following lights defined:
Default Ambient
Default Distant
Lightbulb-2
Lightbulb-3
Lightbulb-4
Spotlight-2
Of these, they are all switched on, except the Default Ambient.
Clearly, at some stage I, or someone else, has created this set of lights.
What I don't understand is this: Where is this set of lights stored? What is its filename?
I would like to modify the file so that the Default Distant light is switched off as standard.
How do I do that? I know how to switch it off, but the off setting does not persist. Next time I open the same part, the Default Distant light is back on.
I have looked in config.pro, but I can't see anything relevant.
Any suggestions?
WF4, M220
John
Best answer by creodential
Hi John,
when you choose the "load default" button, WF4 looks for "default-lights.dlg", but it doesn't matter whether this file is present or not. If it's present, you'll get no error message, but the settings are the same.
Its been a while since I've dealt with light settings, but your problem rings a bell. I think what I figured back then, is that the settings for "default distant" and "default ambient" are stored somewhere in the code.
I "solved" this for our purposes by creating a bunch of mapkeys, providing different light settings. One doesn't fit it all, anyway.
Andreas
Hi John,
these information are stored in files, have a look at %PRO_DIRECTORY%\graphic-library\lights\*.dlg
HTH,
Andreas
JWayman1-VisitorAuthor
Andreas,
Thank you.
I had worked that much out, but I do not know what file the software is looking for to load its default lights. What should the file be called and where should it be? I imagine it should reside in <loadoint>\graphic_library\lights. There is a file called default-lights.dlg in that directory, but, if I click 'load default lights' in Pro/E, I see the message 'default lights file not found'. I therefore have no idea what the default lights file should be named.
Sorry I wasn't more clear about my problem earlier.
John
Thanks, Andreas. I was aproaching that conclusion, reluctantly!
Never mind, mapkeys will do the trick.
Cheers,
John
