Losing changes
We turned ModelCheck on back in July. Since then a couple of the designers have reported that when the reopen an assembly the next day or later, the changes they saved have not been saved. I turned it off for the past 10 days and one user reported no issues with ModelCheck turned off. We are not preventing check-in to WIndchill for errors, everything that would be an error is right now only being flagged as a warning.
We do know that ModelCheck slows down the check-in process. I had to block 4 files from running ModelCheck as it was taking over an hour to process the drawing on check-in.
I have cautioned the users to watch the rolling arrows at the bottom of the screen and not close their part or Creo while the arrows are rolling.
Is there anything else to set or check in ModelCheck, Creo or Windchill that will prevent lost work?
We are on WIndchill 11.0 M030 CPS16 with Creo 4 M080.
I can move to M150 if that might help. I am working on a total upgrade to Windchill 11.1 M020 and Creo 7 or 8.
