7-Bedrock
December 30, 2022
ModelCHECK, ACCURACY_INFO does not update absolute accuracy values. It does update relative values
  • December 30, 2022
  • 2 replies
  • 2991 views
I am using Creo Parametric Release 8.0 and Datecode8.0.5.0
In ModelCHECK, ACCURACY_INFO does not update absolute accuracy values. It does update relative values
Best answer by lgreene
I did . . . resulting in SPR 14464196.
Development team has fixed the issue and the fix will be available in Creo Parametric 8.0.9.0. and 9.0.5.0.
Perhaps the setup of your ModelCHECK is not taking into account that the limits are defined by different parameters depending on whether the accuracy is absolute or relative. A quick online search using "creo modelcheck accuracy_info" yields the following:
ModelCHECK Accuracy
In brief, it calls for:
ACCURACY_LOW and ACCURACY_UPP for relative accuracy
MIN_ABS_ACCURACY and MAX_ABS_ACCURACY for absolute accuracy
lgreene7-BedrockAuthor
7-Bedrock
December 30, 2022
Thanks for the reply. Yes I did consider the limits for both Relative and Absolute
I can change the accuracy to the absolute value in the regular, manual way just not with MC
By ModelUPDATE mode, Creo ModelCHECK automatically changes the accuracy to this value if the accuracy is not within the acceptable limits.
Use this syntax in the start configuration file:
MU_ACCURACY ABSOLUTE 0.001
7-Bedrock
January 2, 2023
Thank you for providing your comment.
ModelUPDATE mode is a bit too aggressive for me.
I want ModelCHECK to warn of unacceptable accuracy value and provide the option to change it then.
7-Bedrock
January 11, 2023
Thanks for the recap of the help files.
I've got a ticket in on this. 16689343
