Parts open in "My Document" view but doesn't show inside CREO [Quite Urgent]
rgoh
Hi guys,
I've tried duplicating my files and renaming them because I need to put them into my lecurer's dropbox. I did this simply by going into the "My Documents" view and copy+pasting.
However when I do this not all the parts seem to be visible inside CREO. I can open most of them from the My Documents view (as they are visible) though.
Here is a screenshot of what I mean.
The left side is the Docs view, and the right side is from within CREO.
How do I properly make a duplicate of my files so they show up?
Thanks guys.
TomD.inPDX
(To:rgoh)
The name is probably too long, or you have spaces beyond the ...
And the hole_punch_assembly doesn't have a valid extension.
rgoh
(To:TomD.inPDX)
It ended up working when I individually did "Save as" for every part, and made duplicates that way. Basically the ctrl+c and ctrl+v method didn't work properly.
Thanks anyway
MartinHanak
(To:rgoh)
Reuben,
if you want to get some explanation, you have to upload new picture of Windows Explorer window.
1.] you have to turn Hide extensions for know file types option off in Windows Explorer
2.] you have to modify size of Name column to display complete file names
Also it is better to put files into the directory, whose name does not contain spaces.
Martin Hanak
Martin Hanák
