Please Help. Wildfire 5.0 Node Locked install failing after windows installation
  • November 16, 2020
  • 2 replies
  • 16669 views
I hope some people are out there still using Wildfire or know what is wrong. My Pro/e was working fine but I had to do a clean install of windows 10 and then reinstall my Wildfire version for the DVD. Now I cannot get my Pro/E to install correctly. I get the frustrating error:
(-96) License server machine is down or not responding
This is a node locked installation and I have the license file. I have tried what I understand from this article
https://www.ptc.com/en/support/article/CS21768
Any help would be greatly appreciated. Kind regards, Justin
Best answer by MartinHanak
@JK_3224567 wrote:
Thank you Martin for you input,
I didn't install the PTC License Server since I want it node locked, so I don't have Imadmin_ptc service or FLEX net running on my machine. I double checked looking in the Task Manager.
I also checked the proe1.psf file and it looks correct. I added the top line as suggested in the article I mentioned in my original post.
ENV=PRO_ALLOW_FLEXJOB=true
ENV=PTC_D_LICENSE_FILE-=C:\PTC Files\license.txt
ENV=PROE_FEATURE_NAME=PROE_FoundationAdv ()
Regards, Justin
  • install License manager using setup.exe from Wildfire 5.0 DVD. Use C:\PTC Files\license.txt license file
  • when installation is finished, FLEXlm server for PTC service is available
  • to verify license availability launch ptcstatus.bat from FLEXnet installation (the path could be C:\Program Files\PTC\flexlm\bin\ptcstatus.bat)
  • when license is available then modify proe1.psf
    ENV=PTC_D_LICENSE_FILE-=7788@nameofyourpc
  • turn off Windows Firewall
  • start Wildfire 5.0
I hope you have your license file safely backed up.
1.] stop lmadmin_ptc service
2.] uninstall FLEXnet license manager
3.] edit proe1.psf file in PROE\Parametric\bin directory
The file must contain two following lines configured properly.
ENV=PTC_D_LICENSE_FILE-=full_path_to_license_file
ENV=PROE_FEATURE_NAME=PROE_license_name (optional module numbers if some exist)
Regards, Justin
@JK_3224567 wrote:
Thank You Martin, You know your **bleep**!  And thanks to the other members who offered help. someday I will have to buy the upgrade.
FYI,
I didn't need turn off the windows firewall, but yesterday I had added some exceptions from another PTC article so maybe that is the reason. The ptcstatus.bat would flash a window open for split second, but nothing seemed to happen.
Thanks again, Justin
to see license status info, open Command prompt window and launch ptcstatus.bat in it.
Is Wildfire 5.0 supported on Windows 10?
Wildfire 5.0 is not supported but it works.
