Possible to use Reconfigure to have one configuration that pulls a local license, and another that pulls a license from a license server?
swalsh
2-Explorer
I have a user who is working remote.  He has a laptop with a local license that works for most applications.  Occasionally he needs to use a license we only have on the license server as a floating license.  Is it possible to have two configurations; one that pulls from the local file, and the other that pulls from the license server?
5 REPLIES 5
Mahesh_Sharma
22-Sapphire I
(To:swalsh)
Scott,
Yes, you can create two configurations for Creo start. This all needs to be done using reconfigure.exe which is in <Install dir>\parametric\bin.
Once you will execute reconfigure.exe move to second window > Add License server (which will provide additional license) > Next > Customize Application > Command Configuration > Add > Change Description and name of command > Have required license in left which is needed for that specific startup command > Ok > Ok.
This will create two commands and which user will execute Creo there will a window to select start command.
I hope this will help.
This is exactly what I have tried.  Once the license server is installed however, the local license is ignored and it always pulls a license from the server.
Mahesh_Sharma
22-Sapphire I
(To:swalsh)
Scott,
Try making changes for license priority in PSF files (available in bin folder).
Edit line for PTC_D_LICENSE_FILE
ENV=PTC_D_LICENSE_FILE-=7788@LOCAL_LICENSE_SERVER;7788@REMOTE_LICENSE_SERVER
MartinHanak
(To:swalsh)
I prefer managing startup configurations manually in Notepad instead of using reconfigure.exe.
1.]
In CR2 go to Creo2_loadpoint\Creo 2.0\Parametric\bin directory
In CR3 go to Creo3_loadpoint\Creo 3.0\Mxxx\Parametric\bin directory
2.]
Installation manager creates parametric.psf configuration by default.
If you need more than one configuration, you can copy parametric.psf several times and rename copies according your needs.
3.]
Inside psf file there are 3 important lines:
DESC=here you can type any text describing the purpose of startup configuration
ENV=PTC_D_LICENSE_FILE-=7788@servername
ENV=CREOPMA_FEATURE_NAME=licensename (extension list)
Example:
DESC=Creo Parametric
ENV=PTC_D_LICENSE_FILE-=7788@servername1;7788@servername2
ENV=CREOPMA_FEATURE_NAME=PROE_FoundationAdv (127)
4.]
If you create shortcut to parametric.exe and launch Creo using it, you will see dialog box containing list of startup configurations.
MH
Martin Hanák
Mahesh_Sharma
22-Sapphire I
(To:swalsh)
Scott,
Did you manage to get it working?
