ProE file version checking tool?
BarrySchaeffer
2-Explorer
ProE Gurus,
I have a large number of ProE files in folders which were saved using different versions of ProE (Wildfire 1 thru 3).
I want to rapidly identify the subset of those which were stored in versions prior to WF3.
Is there a tool available for this purpose? Perhaps a method using a tool like grep?
Thanks in advance. I will publish a summary of any methods that work.
Barry Schaeffer
Fluke
Everett WA
2 REPLIES 2
On 05/05/11 17:35, Schaeffer, Barry M wrote:
> ProE Gurus,
> Barry Schaeffer
> Fluke
> Everett WA
On Solaris this shell script will do this
#!/bin/sh
for file in *
do
version="`head -1 $file | awk '{print $9}'`"
if [ "$version" -lt "2700" ]; then
echo $file
fi
done
What this does is loop thru all the files in the current directory and
finds the version by taking the 1st line of each file (head -1 $file) pipe
that to awk to extract the 9th field of that line. Since 2700 is Wildfire 3
it then compares the version to that. If less than "2700" then we have a
pre WF3 file.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Hi Barry,
You can use my ProTrail tool with the -chkvers option.
(download it here).
Copy protrail.exe to the folder (or another folder which is in your PATH)Open a DOS prompt in the folderRun ProTrail:
protrail -dontrun -chkversIt will deliver output like thisSmiley Tonguerocessing file 300709296.prt.1
File 300709296.prt.1 was created with Wildfire 4.0 (M190)
Processing file din_125b.prt.1
File din_125b.prt.1 was created with Wildfire 4.0 (M140)
Processing file din_6325-old.prt.1
File din_6325-old.prt.1 was created with Wildfire 4.0 (M140)
Processing file din_7991.prt.1
File din_7991.prt.1 was created with Wildfire 4.0 (M140)Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Fico B.V.
Ratio 6, Duiven
Phone: +31 26 3196215
Mobile: +31 644548554
www.besi.com
To: "Schaeffer, Barry M" <barry.schaeffer@fluke.com>
Cc: "-" <->
Date: 06-05-2011 16:59
Subject: [proesys] - RE: ProE file version checking tool?
